Old 02-24-2008   #1 (permalink)
Favorite Bike: MY SILVER '05
Question Optimate charger
I recently bought an Optimate 3SP. Because I am not able to get out and ride every weekend, and with the recent cold weather when the Temp in the garage where I keep the girlie often falls below -5, I thought it would be a good idea to keep it on trickle charge. I bought the adaptor so that I could plug it straight into the power take-off socket. First time I switched it on, the power ON light illuminated and so did the red WARNING light. As far as I know the battery is in good condition - spins the engine over easily and she fires up every time. Does the red light mean it requires no charging or is something wrong? This query is necessary because I have lost the instruction leaflet! Any advice welcome.
Mike
TIGERBLOG is offline   Reply With Quote
Old 02-24-2008   #2 (permalink)
Favorite Bike: 2006 Triumph Tiger Black
Other Motorcycle: 2004 Speedmaster
The red LED indicates a weak battery, or at least the voltage has dropped below 12.2V. If that were true, I doubt you'd be able to start it. My guess is you have a voltage drop either in your auxiliary outlet plug you are using or in the auxiliary plug circuit itself. That is actually not all that unusual, OEM wiring circuits are notorious for voltage losses.
To check, use the charger directly on your battery with the alligator clips, do you get the same indications? IF so, you got a weak battery. If not check the resistance with an ohmmeter from your auxiliary plug back to the negative and positive cables (with the battery out). IF that is more than a few ohms, you got a bad connection somewhere, and need to clean connectors etc....
Digger is offline   Reply With Quote
Old 02-24-2008   #3 (permalink)
Optimate charger
I have a 2001 955i Tiger and have been using an optimate for three years. Occasionally the red light on the optimate comes on when I turn the charger on and the battery is fully charged. I find that if I disconnect the charger for 30 seconds and then reconnect that the red light has gone out.
Dingo
Dingo is offline   Reply With Quote
Old 02-26-2008   #4 (permalink)
Favorite Bike: Triumph Tiger
MAX21's Avatar
Might sound like a daft question but did you make sure the + & - are the right way round when you put the plug on?
MAX21 is offline   Reply With Quote
Old 02-28-2008   #5 (permalink)
HiVel's Avatar
If I remember correctly the Optimate is to be connected and then disconnected-then reconnected as it programs itself for the proper cycle for your battery. The redlight goes on , but if you disconnect and reconnect it should go out and go all orange until the battery is fully charged -then it will go green. Read the instructions please! You may have a bad battery?
Try the drill-plug in , unplug, and re plug-see if that is it.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 03-03-2008   #6 (permalink)
Favorite Bike: Tiger 1050 '08
Other Motorcycle: Tiger 955i '06
Exclamation Charging in -5 ?
I do not think it is a good idea to charge SLA (Sealed Acid) batteries in temperatures under 0. Any SLA battery can be safely charged when temperature is above 0.
Otherwise it might damage the battery.
slayer is offline   Reply With Quote
TT600 - Optimate charger and batteries Zed Triumph SuperSports 13 05-09-2007 08:09 PM
optimate charger crogger T3 Sport / Touring Forum 5 09-11-2006 10:17 AM
Accumate vs Optimate BigVinny Modifications & Workshop Talk 2 12-19-2005 07:09 PM
Optimate 111 Billy Sprint Forum 7 12-18-2004 09:38 AM
Optimate III Tiger Chat 7 05-14-2004 04:56 AM
