Don't know if your bike has a secondary air injection (SAI). On the 1050's there is a solenoid controlled air injection coming off the air box which ties into the top of the engine. Disabling the SAI will eliminate the poping on decel. Removes the air source that allows the excess gas to ignite in the pipe.
There are several ways to disable it, anywhere from simply unplugging the power to the solenoid to completely removing all the clap trap and making custom covers to make it look like it was never there. On my '05 1050 Speed Triple, unplugging the power from the solenoid wiould cause an engine error light. Installing a resistor across the power feed tricked the ECU into thinking the solenoid was still there, no more error light. 25 ohms I think but measure the solenoid to be sure.
