If you use good quality top brand fuel (Shell, BP, Chevron etc.), you shouldn't need any injector cleaner because the fuel has cleaning additives in it already. I'd syphon out as much as you can and refill with clean fuel. Maybe add a little bit of the drained fuel into a full tank, bit by bit, to get some use of it later.
Of course, having said that, it just occurred to me that you may have added far too much additive. One can, which you say you added, is probably enough for a car tank. i.e. 12 gallons or so. NOT the 5 gallons in a Tiger's tank. Could be that it needs thinning down a bit.
H
'02 Tiger955i in black.
