Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
ShopTriumph.com
Old 01-23-2008   #1 (permalink)
Question Weatherproof switch
Hi,
I am about to add an LED driving light to the front of the Tiger, but I'm no auto electrician !, I'm trying to find a simple waterproof switch I can mount that will allow on and off, and if it has a momentory on posistion as well that would be even better !.
There are stacks on RS and Farnell, but I don't understand what I'm looking at,
Have you guys any ideas ?
Thanks in advance for your help.
Cheers,
All the gear and no idea !
snaphappyuk is offline   Reply With Quote
Old 01-23-2008   #2 (permalink)
In the US Harley shops are a good source for auxiliary stuff like that. Probably not common in the UK. Maybe a boat supply house.
littlefield is offline   Reply With Quote
Old 01-23-2008   #3 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
I've used number 36450 on this page from vehicle wiring products for a changeover high level brakelight / fog light for mine. It seems quite well made but I haven't got it wet yet.....
It fits quite neatly next to the heated grips switch.
VWP are an excellent source for lots of stuff.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 01-23-2008   #4 (permalink)
Favorite Bike: tiger 955 05 silver
snakebasket's Avatar
Other Motorcycle: Laverda sf
Extra Motorcycle: Triton
I used a metal toggle switch like the ones from VWP, sourced from Maplins with a waterproof rubber cover for my aux, lights (located in fairing next to heated grips switch) . Has been subjected to much wet weather without problems.
snakebasket is offline   Reply With Quote
Old 01-25-2008   #5 (permalink)
Favorite Bike: Tiger 955i '06
BoneyMalloney's Avatar
First, make sure it's the correct voltage and current rating or it will burn out. Same applies to the wire you use... Watts divided by volts equals current, this should narrow your search!
Where did you get your light?
Chris.
BoneyMalloney is offline   Reply With Quote
Old 01-31-2008   #6 (permalink)
Thanks for all your help, Maplins it is then !,
The light came from EVS
http://www.emergencyequipmentshop.co...96f6fe7e8aa7ec
I bought it as I have a hell of a lot through London Commuting to do, and a bit of extra visability cant hurt !
Don't thing the boys in blue will approve of the flash patterns though !
Old 01-31-2008   #7 (permalink)
Favorite Bike: Black 2002 Tiger
Above the starter button on the throttle side of the handlebar there seems to be a pop-out filler which could be used to take a switch. Does anyone have any knowledge of what could go in there. I have not been able to find any information from fiche or manual.
rainycoastguy is offline   Reply With Quote
Old 01-31-2008   #8 (permalink)
It was the place for the on/off switch for the lights.
MrGromit is offline   Reply With Quote
Old 01-31-2008   #9 (permalink)
Is the switch still available...and is there a part number? It is a great place for an auxiliary light switch.
Old 01-31-2008   #10 (permalink)
Favorite Bike: 2005 Bonneville Black
Have you checked Painless Wiring?
2005 Bonni Black; Reverse Cones, Pods, No AI, 145, 42, Thrux Needles, 1.75 Turns Out, Iridium's, EBC Brakes, Speed-Bleeders, and a pile of stock parts.
SCL18 is offline   Reply With Quote
oil switch hificus Club Cafe 3 12-15-2006 11:51 AM
Kill switch versus ignition switch? boredinocala Sprint Forum 13 09-10-2006 09:03 PM
When to switch to reserves? BoiseTwin Twins Talk 17 03-11-2006 09:14 AM
Weatherproof GPS? kuhlka Speed Triple Forum 16 11-23-2005 07:48 AM
switch vinceg Triumph SuperSports 9 06-25-2005 09:40 PM
