Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 01-27-2005   #1 (permalink)
Well, I noticed coolant leaking a month or two ago on my '99 885 Tiger and saw the weep hole of the water pump was putting out the coolant as far as I could tell. I replace the water pump and then noticed a smaller pool of coolant forming only when the engine was cold and warming up. The drip would go away after the engine was up to operating temp.
Further inspection revealed a leak near the exhaust header so I figured the head gasket had gone bad. I took it to the shop last week to get it replaced. Fortunately I'm due for a valve check, oil change, spark plug change, coolant change so I'm not to disappointed. Anyone have other suggestions on mods while the bike is torn down? I'm already looking at $500 or so for the current work so I don't want to sink a lot more into it at the time.
BShell is offline   Reply With Quote
Old 01-27-2005   #2 (permalink)
I had a slight leak on the right side head gasket. They ended up having to machine the head. Not sure how that is determined but it may be a factor on your repair.
05 Thruxton
whoa is offline   Reply With Quote
Old 01-28-2005   #3 (permalink)
Favorite Bike: '96 Tiger
Mudhen's Avatar
Other Motorcycle: '06 Scrambler
Get the head decked anyway while it's out, even if you don't need it....mmmm....power...
I've heard this spoken of in hushed tones in dark corners of some pretty shady pubs...but never actually read a first hand account of someone doing it. I think it raises hp to like 150 and drops the weight about 100lbs
M
[ This message was edited by: Mudhen on 2005-01-28 07:39 ]
Pat
'96 Tiger
Mudhen is offline   Reply With Quote
Old 01-28-2005   #4 (permalink)
When the service manager told me that I will notice a difference in power, it didn't occur to me this is what he meant. He said it in a very approving tone. Thanks for point this out.
05 Thruxton
Old 01-29-2005   #5 (permalink)
Mudhen's Avatar
I wonder if you needed a different tune because of it...ever had the bike on a dyno since having it done?
Pat
'96 Tiger
Old 01-29-2005   #6 (permalink)
Just got the bike out of the shop tonight. I'm going to run a few hundred miles up pretty quick and get it back in for a check. I'll ask them when I return the bike.
05 Thruxton
Old 01-31-2005   #7 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
It's very unlikely enough was shaved to make any noticable difference. In my experience (of working several years in an engine shop), you have to take quite a bit off before you get any noticiable compression performance benefits. To true a head only usually takes a few thou'.
Mick...
T100C Head gasket replacement tips? Ahobie17 Classic, Vintage & Veteran 2 07-29-2007 09:09 PM
head gasket annealing firedog Classic, Vintage & Veteran 6 12-30-2006 10:30 AM
Head Gasket?? triumphrdr Speed Triple Forum 14 11-12-2005 08:41 PM
Head Gasket??? flick427 Twins Talk 8 08-02-2005 11:36 AM
head gasket Triumph, Models & Dealers 0 08-18-2004 12:23 AM
