Originally Posted by kiwi tony
Hi can anyone supply part number for the inner seal on the clutch shaft that is accessed behind the front sprocket cover on 885 carb model steamer.Mine is leaking since the crash and if I provide the number hopefully will get the right one when ordering.Thanks in advance Tony.
Start belowfor a schematic of the Tiger. You will need your serial number.
http://www.bikebandit.com/triumph-TIGER/oem-parts
Not sure of the location described, are you referring to the output shaft, part 28: SEAL,OIL,40 62 6?
http://houseofmotorcycles.bikebandit...m6912sch513816
Or 5: OIL SEAL & SHIM WASHER KIT
ENG NO 83309 AND BELOW
http://houseofmotorcycles.bikebandit...m6912sch513518
Lots of chain drive motors leak oil when the countershaft fixing bolt or nut (depending on model) and the countershaft sprocket are loose on the output drive shaft.
