BikeBandit
Old 11-07-2007   #1 (permalink)
changing brake pads
Is it easy the change brake pads? I have some on order from Triumph-online and research has told me that you:
a) Undo the calipers (or whatever there called)
b) undo a pin/screw which holds the pads in place
c)pull out old pads and clean up with brake cleaner but certainly not to allow pistons out very far
d) install new pads
e)re-screw in the er...screw smeared with copper grease
f)Re attach brakes
g) wash off all the copper grease i smeared myself in for part e.
Is that the basic process?
Thanks for any advice.
boocat2 is offline   Reply With Quote
Old 11-07-2007   #2 (permalink)
Yes, that's near enough it. A very easy job to do.
The pistons sometimes seize on older Tiger's, so check they are relatively free moving while you've got the brake apart.
Regards,
Graeme.
graeme is offline   Reply With Quote
Old 11-07-2007   #3 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
Best to do your (b) before (a), or at least slacken off the pin as it can be tight and it's easier when the caliper is still fixed to the bike. As you may know, there's a slotted blanking plug which covers an Allen-headed pin.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is online now   Reply With Quote
Old 11-07-2007   #4 (permalink)
You don't need to remove the front calipers to replace the front pads. It's just the one brake pad pin and they will drop out.
Does anybody know the torque figure for the REAR caliper mounting bolts?
Pickaxe is offline   Reply With Quote
Old 11-07-2007   #5 (permalink)
blacktiger's Avatar
But you can't clean inside the caliper while it's attached to the fork leg. I'd recommend you clean around the pistons quite thoroughly before you push them back into the caliper. This will prevent any dirt damaging the seals. Brake cleaner and an old tooth brush works fine.
Only use copper slip on the thread of the pin. Lightly emery the part of the pin that goes through the pads. Any grease on that part will accumulate dirt and stop the pads from sliding. A light smear of copper grease on the back of each pad will prevent them from squealing.
H
'02 Tiger955i in black.
Old 11-07-2007   #6 (permalink)
pineygroveshop's Avatar
I recommend soaking the hex pin/screw with a penetrating oil before attempting to loosen. Also, be sure to get a good bite with the allen wrench when loosening. The head is easy to mess up and then you are "screwed."
Cheers,
Stephen
Pack Leader
CARAT
pineygroveshop is offline   Reply With Quote
Old 11-08-2007   #7 (permalink)
Agreed. When I aquired my first Tiger (secondhand) I discovered this when I overhauled the brakes. New pins were needed all round because I had destroyed the heads of the old ones in an attemnpt to loosen them. I recall hammering in an old torx socket to get purchase!
With my 06, I've vowed to clean up and lubricate the callipers before every winter - in fact I've just done this and they are working like new for max 1 hour's work, all told (there is no need to disturb the brake lines or fluid). With additional removal for pad changing, there are at least two opportunities each year to make sure the pad pins don't seize.
Jon
Jonny955 is offline   Reply With Quote
Old 11-14-2007   #8 (permalink)
Other Motorcycle: 06 Tiger
Did the rears on my 06 today - 40 Nm
riccih46 is offline   Reply With Quote
Old 11-17-2007   #9 (permalink)
Other Motorcycle: Ducati 749
I find the calipers need freeing off at least twice a year and the pin seems to tighten up on its own so be very careful not to overtighten, little more than finger tight.
greenman is offline   Reply With Quote
Old 11-17-2007   #10 (permalink)
Thanks for that.
Dave
Brakes - Changing Pads on ABS model? brumey Sprint Forum 6 05-15-2008 08:37 PM
Changing Pads - Recommendations GRG-Sprint1050 Sprint Forum 4 09-27-2007 07:06 PM
changing brake calipers doodledog Daytona Deliberations 2 08-13-2007 05:32 PM
Changing rear pads? amanger Sprint Forum 5 08-09-2007 04:32 AM
changing front brake pads punisher Triumph SuperSports 1 03-17-2005 06:14 PM
