Rear brake - piston advice
Okay, I managed to get the pistons freed up, but they won't retract very far.
In fact, there's not enough room to slide the new pads in, let alone then put the assembly back over the rear disc.
Should the pistons slide right inside their sleeves or, if not, how much should be sticking out?
Thanks for your help. Otherwise I'll be putting the old pads back in and ride to a dealer.
