ShopTriumph.comAdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com Classifieds!BikeBanditAnnitori DistributingCycleGear.comTriumphPerformanceUSAbritishcustomsSportbikeTrackGear
Old 10-20-2007   #1 (permalink)
centerstand
Not having a good day.
Firstly a £50 parking fine for parking me bike "to the inconvienience of other customers" Especially if they had bums which were seven feet wide.
Also when I got home I put my bike on the center stand and it nearly fell over because the bolt on one side has fallen out. I have found it on my garage floor. Just one question...is there only one bolt needed to fit each arm of the stand on?
Boocat
boocat2 is offline   Reply With Quote
Old 10-20-2007   #2 (permalink)
On my 06 Tiger there are 2 bolts that go through the footpeg mounts and through the centre stand arms. They came loose shortly after I bought the bike making the footpegs loose. Its a common problem , you need to put locking nuts on the back of the bolts to keep them in place
Parky is offline   Reply With Quote
Old 10-21-2007   #3 (permalink)
pineygroveshop's Avatar
Two on each side of mine. I installed it myself and the screws had loctite on them. I should check them anyhow.
Cheers,
Stephen
ONSR Leader
pineygroveshop is offline   Reply With Quote
Old 10-24-2007   #4 (permalink)
U used stainless steel nyloc type but this is a good reminder for me to check the tightness.
Jon
Jonny955 is offline   Reply With Quote
centerstand HELP! JKDJose Twins Technical Talk 15 03-03-2008 12:16 AM
The centerstand is here! dertbikdennis The Rocket Science Forum 10 05-18-2007 10:40 PM
Centerstand... why do it? rstover Twins Technical Talk 9 04-15-2007 10:50 PM
CENTERSTAND 05 S3 BUCKET Speed Triple Forum 0 05-08-2006 09:27 PM
98-99 Centerstand Hinckley Classic Triples 4 11-16-2004 12:52 PM
