Old 10-23-2007   #11 (permalink)
Favorite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
Extra Motorcycle: '62 AJS 650 Twin
I think you're right littlefield, the fault first appeared to be like a connection fault and we've done the loop and it's right back to a poor connection/grounding problem suspicion.
Keep looking BT, let's know how you get on.
Ride on !
Tbirdnz is offline   Reply With Quote
Old 10-24-2007   #12 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Originally Posted by Bluetiger901 View Post
I will start with the ignition switch then the solonoid. The other contacts were all checked.
If anyone else reads this and has any sugestions pls feel free to coment or help.
I will keep you posted the next time I log on.
Did you actually check for dry joints? The leads (wires) where they are soldered into the teminals? I've had a nasty time tracking down similar problems on my old Harley, only to find that whilst the battery terminals were in great shape, the wires into the terminal connectors. A bit of heat and solder on all of them sorted it out.
Worth a look.
Mick
My Album
miker is offline   Reply With Quote
Old 10-24-2007   #13 (permalink)
Red face Will do !
Will check for poor solder joints at battery terminal.
I have a 12v light tester and will try checking for power at diffrent spots when it fires up properly and when it fails.
As soon as I find something I will get back...
Bluetiger901 is offline   Reply With Quote
Old 10-24-2007   #14 (permalink)
Neutral switch
Does anyone know where the neutral switch is located on the bike. I see this switch in the service manual diagram but can't find it on the bike ? Is it in the cluster panel ?
The battery connections look good. I think I will go for a ride recreate the problem and then check with my test light for voltage at diffrent spots.
any ideas...????
Old 10-24-2007   #15 (permalink)
Moderator
miker's Avatar
Can't say for sure on your bike, but the neutral light switch should be on the left side of the crankcase, as you sit on the bike, up and inside the gear leaver. It will have a single wire terminal pushed on to it.
Does yours also have a side stand cut out? As in, won't start in gear with the side stand down? Worth another look at that one....
Mick
My Album
Old 10-25-2007   #16 (permalink)
Tbirdnz's Avatar
Just seen another similar fault on another forum, they suspect the clutch switch, this is a cut-out to stop the bike starting in gear. If this switch sticks you won't be able to start the bike.
To check this wait until the bike won't start again then pull in the clutch lever 3 or 4 times and then try to start. Pulling in the clutch lever should unstick it. You could of course try cleaning this switch.
Ride on !
Hard Start When Warm Motley Twins Talk 8 10-06-2007 03:01 PM
Won't start warm Ed Earl Speed Triple Forum 19 08-20-2007 06:20 PM
Warm engine won't start Mindawass Twins Technical Talk 4 01-08-2007 12:21 PM
Warm Start Issue: Help diagnosing? Captain_Rat Speed Triple Forum 12 10-05-2006 11:51 AM
03 Tiger -- warm start difficulty ? Tiger Chat 3 04-03-2004 08:36 AM
