AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.comMotorcycle.com
Old 12-15-2004   #1 (permalink)
almost too embarrassed to ask..but whats the PSI for the standard 04 tiger tyres..? the handbook has it in kgn or kgf or something..? i dont know how to convert it... :???:
[ This message was edited by: RobUK on 2004-12-15 21:23 ]
RobUK is offline   Reply With Quote
Old 12-15-2004   #2 (permalink)
Old 12-16-2004   #3 (permalink)
36 psi front. 42 psi rear.
Growing old disgracefully
Badger955 is offline   Reply With Quote
Old 12-16-2004   #4 (permalink)
Old 12-19-2004   #5 (permalink)
thanks :wink:
Old 01-01-2005   #6 (permalink)
Pressure info is also on the tag on the forks behind the lights. Or at least it is on American market bikes
jradamson is offline   Reply With Quote
Old 01-10-2005   #7 (permalink)
May I add that Tigers and modern radial tyres are very sensitive to pressures. Even a drop of a few PSI can change the way the bike handles - that is it gets very squirmy below about 35 PSI in the front. Don't rely on service station guages as they can be way out. Invest in a Michelin guage and keep it on the bike. I use 44 PSI in the rear and 39 PSI in the front using Michelin Anakees. Different tyres like different pressures and in general, a few PSI more than recommended is fine.
I have heavy duty tubes fitted and both front and rear tyres loose a few PSI over about 4 weeks. I check them every second or third tank of fuel - that is every 2 weeks or so.
Timtiger is offline   Reply With Quote
Old 02-27-2005   #8 (permalink)
Other Motorcycle: Ducati 749
Timtiger,
My tyres also regularly lose some pressure and frequent checks are essential. Its ages since I ran tubed tyres, but my experience is that tubeless ones on cars & bikes only lose if pressure if punctured or have faulty valve.
My other 2 wheelers (bicycles) all run tubed tyres and also lose pressure over time, though they do start from a higher level (100psi) and the tubes are not exactly heavy duty!
Dave
greenman is offline   Reply With Quote
Old 02-27-2005   #9 (permalink)
djr
I must admit mine seldom loses any pressure at all. I have not found tubed tyres to be any better or worse than the Tubeless on my TT
David
My Photo Album
My Tiger pages
djr is offline   Reply With Quote
Old 02-27-2005   #10 (permalink)
Like you David mine hardly loses any pressure, even after a two week lay up.
By contrast, the trophy needs topping up regularly, it also tells me sonner than the tiger if the pressures are low.
[ This message was edited by: tango on 2005-02-27 12:32 ]
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
tyre pressures English_Spanner Twins Technical Talk 20 10-09-2006 08:52 PM
Tyre Pressures Tigerbob Tiger Workshop 9 08-21-2006 03:01 PM
tyre pressures gsp0702 Tiger Workshop 7 05-12-2006 12:15 PM
tyre pressures okiecityflash Classic, Vintage & Veteran 17 05-07-2006 12:58 AM
Tyre Pressures mjsharpe Club Cafe 0 03-02-2006 04:02 PM
