» Log in
User Name Not a member yet?
Register Now!
Old 12-11-2004
BigStripey's Avatar
Hope this helps, i have listed a lot of the more common torque settings for the Efi Tigers.
Pad retaining pins Front 18 nm/13.25 ftlb Rear 28 nm/20ftlb
Caliper mounting bolts 28 nm/20.6 ftlb
Brake hose banjo bolts 28 nm/20.6ftlb
Front disc(rotor) bolts 22 nm/16.23 ftlb
Rear disc(rotor) bolts 25 nm/18.45 ftlb
Bleed nipples 7nm/ 5.16 ftlb
Front axle bolt 60 nm/ 44.28 ftlb
Rear axle bolt 85 nm/62.73 ftlb
Engine Mounting bolts (Bracket to cylinder head) 30 nm/22.14 ftlb
All other mounting bolts 90 nm/66.42 ftlb
Spark plug caps 10 nm/7.38 ftlb
Valve cover bolts 10 nm/7.38 ftlb
Thermostat cover bolts 7 nm/5.16 ftlb
Radiator mounting bolts 9nm/6.64 ftlb
Silencer and downpipe exhaust bolts 22nm/16.23 ftlb
Rear footrest bolts 42 nm/30.99 ftlb
Brake pedal pivot bolt 27 nm/19.92 ftlb
Handlebar clamp bolts 35 nm/25.83 ft/lb
Steering stem nut 65 nm/47.97 ftlb
Rear Shock absorber mount (upper) 95 nm/70.11 ftlb
Rear Shock absorber mount (lower) 48 nm/35.45 ftlb
Swingarm pivot bolt 88 nm/64.4 ftlb
Front drive sprocket nut 132 nm/97.4 ftlb
Rear drive sprocket nut 85 nm/64.4 ftlb
Hope this helps, i'll leave this at the top as a sticky post
[ This message was edited by: BigStripey on 2004-12-17 13:44 ]
Big Stripey
Old 12-17-2004
and for those of us in the sates....
1 Nm = 0.738 lbf ft
Old 12-17-2004
BigStripey's Avatar
Beanz,
Thanks for that info, i have 'done the math' and converted them to show ft/lbs as well
Cheers
Big Stripey
Old 12-19-2004
Some of the torque settings are really low, like no more than finger tight, so I got myself a 3/8 dr torque wrench which reads 4-20Nm/40-180lbf.in
Things like the camshaft cover are made from soft magnesium and are therefor easily damaged from overtightening, they are only torqued to 10Nm roughly 7ftlb.
I'm not obsesive about torqueing everything exactly, but where there are mutiple fixings I do and I always use the torque for the low ones.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
Old 02-13-2005
ipg ipg is offline
Hi BigStripey
I'm about to change my fork springs, do you know what the torque settings are for the fork tube cap and the fork clamp bolts. Thanks.
IPG
Keep it rubber side down!
MyPhoto Album
Old 02-13-2005
If it is a 955 then the triple tree clamp bolts are all 20Nm and the caps are 30Nm.
Growing old disgracefully
Old 02-22-2005
oldishnovice
Thanks, good info, i'll save this for when I get my Tiger, that'll save me having to use a spark plug for a sump plug! Yes I did do it! Yes I'm a muppet!
Old 03-23-2005
KuzzinKenny's Avatar
Be aware that the 05 Tiger has different torque values, rear wheel spindle nut for example is 110nm.
KK
ps this is what it said in my bikes handbook but have now seen i Triumph data sheet for Tigers from Vin No. 198875 and it is......
rear wheel spindle nut 85 Nm
front wheel spindle nut 60 Nm
brake pad retaining pins 18 Nm
sump plug 25 Nm
iol filter 10 Nm
KK
[ This message was edited by: KuzzinKenny on 2006-04-13 16:32 ]
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
Old 03-23-2005
KK
sump plug 25 Nm
iol filter 10 Nm
KK
Old 08-21-2005
Tassie_Tiger's Avatar
Where can we get the rest of the torque values for '05 Tiger please. My workshop manual still gives 85 Nm for the rear axle, so I guess it wasn't up to date when I bought with my new bike?
Roger Harvey
Hobart, Tasmania
Torque settings Edsfour Triumph SuperSports 5 09-13-2006 12:31 PM
Torque settings quagmire Classic, Vintage & Veteran 5 09-10-2006 03:21 PM
Torque settings please Charlie2 Sprint Forum 4 07-06-2006 12:35 PM
Torque Settings markpeart Tiger Chat 2 03-29-2006 02:20 AM
Help with Torque settings? Multibob The Rocket Science Forum 2 06-27-2005 01:00 PM
