On 2005-03-23 13:00, KuzzinKenny wrote:
Be aware that the 05 Tiger has different torque values, rear wheel spindle nut for example is 110nm.
KK
ps this is what it said in my bikes handbook but have now seen i Triumph data sheet for Tigers from Vin No. 198875 and it is......
rear wheel spindle nut 85 Nm
front wheel spindle nut 60 Nm
brake pad retaining pins 18 Nm
sump plug 25 Nm
iol filter 10 Nm
KK
KK -
Where did you get these values? From what Triumph data sheets, where?
The manual relates to pre- '05, I think, because it relates to the "eccentric clamp bolts".
Thanks - Walt
