Motorcycle.com
Old 11-28-2004   #1 (permalink)
ipg
Wheels off in preparation for new rubber tomorrow. Check at handbook for torque settings; no information at all on wheel removal and more importantly wheel replacement.
Can someone by any chance fill in the gaps please:
Eccentric adjuster clamp - 35Nm
Rear axle bolt - 85Nm
Rear caliper bolts - ??
Front axle bolt - ?? (perhaps same as rear??)
Front caliper bolts - ??
Should you grease the eccentric adjuster casting??
Any help welcome!! Thanks.
IPG
Keep it rubber side down!
MyPhoto Album
ipg is offline   Reply With Quote
Old 11-28-2004   #2 (permalink)
IPG,
Rear caliper bolt - 28Nm
Front axle bolt - 60Nm
Front caliper bolt - 28Nm
Have just finnished doing the very same job myself.l
I haven't greased the eccentric adjuster but might consider smearing a grease seal round the outside, an awful lot of dust gets in there.
Hope this helps.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Old 11-28-2004   #3 (permalink)
ipg
Thanks Davie just what I need. Yeh a lot of dirt and dust around the adjuster, is it a problem greasing it do you think, either grease or copper paste would certainly seal it and also avoid any seizing together of the faces. But perhaps its meant to be a dry face to face contact for the clamp??
IPG
MyPhoto Album
Old 11-28-2004   #4 (permalink)
It's dry from the factory so I'll go with their better judgement on this one.
davie.
Old 11-28-2004   #5 (permalink)
I concur with leaving the eccentric adjusters dry. Lubricant or antiseize would be unlikely to prevent the clamps from working, but there is a lot of stress on that area under hard accelleration and suspension movement. The consequences would not be good if it slipped - thrown chain? - rear wheel lock up at speed? chain smashes the crankcase?
Leave it dry and clean out the dust.
Timtiger is offline   Reply With Quote
Old 11-28-2004   #6 (permalink)
ipg
Thanks guys, will do!!!
IPG
MyPhoto Album
more torque speedblastr Twins Technical Talk 16 09-24-2007 05:43 PM
Torque pstnbly Sprint Forum 2 06-17-2007 12:15 AM
Torque doodledog Biker Hang-Out 6 03-16-2007 07:37 PM
Torque Value WHAT Triumph SuperSports 1 10-05-2006 09:07 AM
Where's the Torque? DennisRa1 RAT - United States 3 10-04-2005 12:44 PM
