BikeBandit
Old 08-14-2007   #1 (permalink)
jgm
jgm's Avatar
Lower shock bush removal (again)
Hi
I've read all the threads on this subject and still have one question:
Does it matter which side I drift it out from?
I'd guess that the "leave the exhaust in place" camp woud have to drift from the left, but at least one post says it has to be from the right.
I've started from the left because it's easier to see what's going on, it moved 3mm no problem but hasn't budged since, so before I hit it any harder I thought, like many before me, that I'd ask you lot.
thanks
John
jgm is offline   Reply With Quote
Old 08-15-2007   #2 (permalink)
Favorite Bike: Maggie, my 1999 yellow Ti
TucsonBill's Avatar
Other Motorcycle: 1989 Honda NX650 (Dominat
Extra Motorcycle: 1968 Honda CT90
I've had the rear swingarm out twice in the last couple of weeks. See the thread "She Busted!" to see why! Both times I drove the bush out from the left, using a 3/8" socket extension as the drift. It's just a bit smaller, and a bit softer than the bushing. It took some serious smacking with a good sized hammer to get it going, and was lots easier - but not real easy - the second time. The first time I removed the exhaust, a real pain with the panniers. The second time I took the swingarm pivot out first and was able to move the swingarm to the rear to get more room to work on the shock bush. It even gave enough clearance to drive it from the right without removing the exhaust if I wanted to. I can probably now R&R the swingarm in less than an hour! But I don't plan on doing it anytime soon! Too much fun!
William Fee
Iron Butt #26777
Tucson, Arizona
TucsonBill is offline   Reply With Quote
Old 08-18-2007   #3 (permalink)
jgm
jgm's Avatar
Thanks, that gave me the confidence to hit it a bit harder, new shock is now installed. I took Big Stripey's advice and loosened the downpipe nuts a bit rather than removing the exhaust entirely. The bush went back in really easily once cleaned up and greased
Glad that's over.
John
Bush Bike DrewDesign007 Twins Technical Talk 8 09-19-2007 02:11 PM
Rear shock removal greenman Tiger Workshop 3 09-13-2007 04:36 PM
Lower Shock Bushings lightning Club Cafe 1 02-24-2007 12:25 PM
Lower shock? HotSkeete Speed Triple Forum 5 08-16-2006 05:44 PM
That Rear Shock bush.. how nehpetsthegrey Tiger Workshop 12 09-11-2005 11:28 AM
