Old 08-06-2007   #1 (permalink)
Favorite Bike: 99 Tiger
Sonoma's Avatar
Oil leak behind front sprocket
For those of you following along at home I have been chasing an oil leak. I have abandoned my old post about an oil leak at the shift lever because it is not leaking from there and that just makes me look the fool . My new suspect is the oil seal on the output shaft behind the front sprocket. I have cleaned out all of the chain lube and know that it is not excess chain lube dripping.
Does anyone have advise on replacing this oil seal. Removing the front sprocket seems easy enough but what about the seal behind it? The seal itself is only $8.00 US but I don't have any experience in this area so any help would be great.
Sonoma is offline   Reply With Quote
Old 08-06-2007   #2 (permalink)
losangeles_S4's Avatar
Check out these two old threads..
http://www.triumphrat.net/showthread.php?t=56538
http://www.triumphrat.net/showthread.php?t=56530
Best,
Erik Hillard
2002 Triumph Speed Triple
1976 BMW R90
losangeles_S4 is offline   Reply With Quote
Old 08-06-2007   #3 (permalink)
Sonoma's Avatar
Thanks Erik,
Looks like you are having or had the same problem. Did you fix it yet? How did it go?
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
Any one have a drive sprocket oil leak? amanger Sprint Forum 7 04-06-2007 06:02 AM
Oil around the front sprocket cover bruin Twins Technical Talk 22 11-22-2006 06:35 PM
Oil leak - front cam gasket Springbok Club Cafe 2 09-20-2005 07:09 AM
oil leak , seals , front sprocket durkster Hinckley Classic Triples 2 01-13-2005 12:09 PM
