AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.comMotorcycle.com
Old 08-02-2007   #1 (permalink)
gear vibration????
hey guys, i just turned 40,000mls on my 1995 and am noticeing a vibration coming from my tranny area. mostly at lower speeds in lower gears, but i also feel it in right hand corners. the bike absolutly needs a chain and sprocket(front and back). but when i pull in the clutch it seems to smooth out. the clutch feels good though. its almost like when you take off in too low a gear and it lugs a bit. any ideas?. my neighbor is a mechanic and doesnt seem to think its anything, maybe im just too worried. i have only owned the bike a short time now(im the 4th owner) and im still getting used to it. thanks
aeronca is offline   Reply With Quote
Old 08-02-2007   #2 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
You said it yourself I think.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 08-02-2007   #3 (permalink)
Smile
your probably right. but even at idle when i pull in the clutch? i might be just to touchy-feely.
Old 08-02-2007   #4 (permalink)
there's a bit of clutch whine/rattle on my 955 when in neutral. Pull in the clutch and it goes away, and always has done.
Worn chain and sprockets will certainly add to the geenral noise/vibration generation, turning right with sideways slack in the chain might make it not run front to back quite true ? I'm guessing here.
I'd certainly replace it if it is that worn, it's like a square off tyre, you try and get your last few pennies worth and when you replace them you ask yourself why you didn't do it sooner.
Luggin in too low a gear, do you mean too high a gear and low revs ? They all do that...
FifeTiger is offline   Reply With Quote
Vibration JACKROCKET The Rocket Science Forum 6 02-14-2008 09:37 PM
'02 955i / Wisconsin / Gear, gear, gear. wwpageiv Daytona Deliberations 2 06-06-2007 11:24 PM
Vibration Amboguzzi The Rocket Science Forum 10 10-03-2006 06:26 PM
Vibration 4philthy Sprint Forum 3 10-03-2006 07:41 AM
S4 Vibration... FuryFour Triumph SuperSports 3 01-12-2006 06:25 PM
