Old 07-24-2007   #1 (permalink)
Favorite Bike: '06 Blue Tiger
Blockhead's Avatar
Beating the coolant spewing horse again
I am curious, did any of you have a coolant spew early in your Tiger's life
then not have it happen again until about a year later? Because that is what
is happening to me. I had a spew at the gas station las summer on a particularly hot day after riding home from work. It didn't happen again until
this week, twice. Not a flood but definitely spillage from the front, most likely
around the top where the hoses go in, and at the over flow hose hanging
behind the right foot peg.
Is it possible the crossed over hoses are not being really a problem until now? Or there is something else like a thermostat that needs replacing since I think it runs hotter than it should at times? It's time for the annual inspection sticker so I think I'm going to have the dealer check my cooling system for
som warranty work!
Block
Blockhead is offline   Reply With Quote
Old 07-24-2007   #2 (permalink)
Favorite Bike: Guess.
Stretch's Avatar
Other Motorcycle: '87 Honda XL250R
Extra Motorcycle: '71 Honda Trail 90
The radiator caps on these bikes don't appear to be a lifetime item. Fortunately they're pretty cheap. Swap in a new radiator cap, as they are frequently to blame for Puking Tigers.
Silver 2005 Tiger
I've never regretted overbuilding anything.
Stretch is offline   Reply With Quote
Old 07-24-2007   #3 (permalink)
Blockhead's Avatar
Well, I feel real stoooopid now, I had too much fluid! My mechanic said to keep it at the minimum level or slightly below. By the time I got to the shop
the level was to the top of the overflow conainer! Way to much. He siphoned some out and going home it actually ran even cooler than it ever
has this time of year.
I guess over full can keep it running hooter than it should. They must think I'm a real rookie there!
Block
Old 07-25-2007   #4 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
Remember that if your pipes are crossed then the fluid in the expansion tank doesn't return to the engine...... And the temperature sensor will read under the "real" temperature if it isn't in water.....
Not to worry you though, I would however recommend that you take the petrol tank off and check that you actually have the engine itself full of coolant, that the pipes are the right way round, and as others have said a new cap won't break the bank.
Mine needed 1.5 litres after it had been "serviced" by a dealer
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 07-25-2007   #5 (permalink)
Blockhead's Avatar
So that means the fluid wouldn't fluctuate in the overflow tank if they are
crossed, right? It would remain constant if there was no circulation.
Old 07-25-2007   #6 (permalink)
iansoady's Avatar
No, it would go up in the expansion tank OK but wouldn't return to the engine when it cooled down as it would be sucking air.
This is my attempt at a sketch showing the layout of the expansion tank which I did for another place.
Ian
2004 Tiger 955i
Old 07-25-2007   #7 (permalink)
Blockhead's Avatar
Excellent graphic! That's what I was thinking too. So, when my fluid
was fluctuating from under min line to over max line the hoses should be correct.
You see what I'm trying to avoid don't you? :-) Taking off the tank and looking for myself...
Block
Old 07-26-2007   #8 (permalink)
iansoady's Avatar
Go on, you know you want to. The best bit is taking it for a blast to use up the petrol so the tank isn't too heavy. Although perhaps not today, looking out at the rain......
Ian
2004 Tiger 955i
Old 08-06-2007   #9 (permalink)
blacktiger's Avatar
Can you see the rain in Texas from Birmingham?
H
'02 Tiger955i in black.
Old 08-07-2007   #10 (permalink)
iansoady's Avatar
When I wrote it I couldn't see Birmingham for the rain.......
Ian
2004 Tiger 955i
This bike can take some beating! R3T The Rocket Science Forum 0 10-10-2006 04:12 AM
Thruxton spewing fuel upon fillup ?? MikeBurke Club Cafe 6 06-01-2005 08:58 AM
Thruxton spewing fuel upon fillup ?? MikeBurke Modifications & Workshop Talk 27 05-30-2005 01:45 AM
bolt took a beating punisher Triumph SuperSports 0 12-21-2004 09:00 PM
Beating a Dead Horse: the Classic Triple Blues mecscc Hinckley Classic Triples 8 04-11-2004 09:22 AM
