Motorcycle.com
Old 06-25-2007   #1 (permalink)
Lovechops
How do you remove the air from the cooling system on my Tiger, Im sure there should be a bleed screw some where but can't find it?
When I have been on a long run and the bike is left to stand for a while all the water hoses start to shrink in,very strange!When you start the bike up the hoses return to their normal shape.
It goes into the dealers on thursday but I just wondered if anyone else has had this problem.
Old 06-25-2007   #2 (permalink)
BigStripey's Avatar
It sounds like the culprit could be the pressure cap itself ? Have you checked that ?
Triumph's for some reason have had problems with the pressure caps (Cheap suply?)
Otherwise, the bleed screw is next to the cap on the thermostat housing. Unfortunately that means lifting the tank (or removing it) to get to it
Big Stripey
BigStripey is offline   Reply With Quote
Old 06-26-2007   #3 (permalink)
Lovechops
OK.. Thanks for that. I will leave it for triumph to sort out . I will keep you posted!
Old 06-28-2007   #4 (permalink)
Lovechops
Yes you were right ....... The pressure cap was swapped by triumph, it sticks apparently and the built up air can't escape.
The dealer said they get through loads of them, which is a bit worrying. If goes again out of warranty I will try and source a car version thats reliable...
Cooling System Issue SportTBird Modifications & Workshop Talk 5 06-16-2006 02:59 PM
Air in cooling system? mathbeak Sprint Forum 3 04-27-2004 07:27 PM
Legend cooling system Modifications & Workshop Talk 9 04-05-2004 08:28 AM
Air in cooling system LRS Tiger Chat 1 03-12-2004 08:33 AM
cooling system ?'s Modifications & Workshop Talk 11 12-16-2002 11:24 AM
