The chain on my 06 when set as Triumph states as 45mm max, was way too tight once you sit on the bike.
Throw away the specs and sit on the bike off the stand, then put someone else on the back with you. Check the slack in the mid point. It should be about 10mm or 3/4 inch fully loaded. Once you have this set, get off the bike, put it on the stand and check the slack, it will probably be between 50 and 60 mm, you can use this measurement for the future. If it's more than this, you can wear the sprocket from the chain riding up on the teeth, if it's less you may damage the bearing or seal of either the countershaft or the rear wheel.
Too tight is way bad, just right is the best, and too loose is better than too tight.
Mick
My Album
