BikeBandit
Old 06-16-2007   #1 (permalink)
After the last batch of torrential rain, arrived home to find 1/2 inch of water in the panniers. I stripped them down yesterday, all nuts and bolts + rivetts. The right hand (exhaust) box had some very brittle type sealer while the other had none at all. Reassembled using quality silicone through each nut and bolt, under handles and around bottom hinges. Sprinkled talcome powder in them and went to work last night as normal. Coming home this morning through some appalling weather and both panniers remained bone dry. Hope this has cured it and wish i'd done it before leaving my ipod and phone in there without swimmng lessons!
itchyfeet is offline   Reply With Quote
Old 06-16-2007   #2 (permalink)
Favorite Bike: Tiger
Other Motorcycle: 89 Moto Guzzi Mille
Extra Motorcycle: 67 BSA 441
I just assume they will leak and baggie everything I want dry.
Sometimes it takes a whole tank before one can think straight
Anthouse is offline   Reply With Quote
Old 06-24-2007   #3 (permalink)
Not only did mine leak, a part of the lock area on both panniers suffered a stress fracture as well. I repaired mine using Sikoflex mastic. I also dismantled all locks and hinges to reseal the previous sieve like construction. Seems to do the job.
CATUCK is offline   Reply With Quote
Old 06-27-2007   #4 (permalink)
Same problem here! The problem is with the hinges and through-bolts rather than the rubber gasket seal between the two halves then? Is disassembly a big job? I have to say that for the money Triumph charge it would seem reasonable to make them watertight...
dmsum is offline   Reply With Quote
Old 06-29-2007   #5 (permalink)
dmsum,
can't speak for all leaks, but mine was definately leaking through hinges and bolts and not the seal. Its not a very long job but your right, doing a job yourself that Triumph should have done never sits well. The good news is that using a decent silicone does seem to do the job.
Panniers v. Beetle Bags and selling my panniers Lancelot The Rocket Science Forum 6 07-18-2007 08:55 AM
something is leaking :( peter_s Twins Technical Talk 3 07-16-2007 04:16 PM
Leaking Coolant scrmpyjack Trophy 4 11-06-2006 01:18 PM
No its really leaking jared26jlvigil2 Triumph SuperSports 5 08-15-2006 07:45 PM
CF Silencer Leaking incorrigible Sprint Forum 6 02-16-2006 08:28 AM
