Old 06-11-2007   #1 (permalink)
My brake light doesn't work on my steamer via the back brake although the bulb seems ok as it works on the front brake lever.
I have cleaned the switch connection but can't see if there is any adjustment and the Haynes manual doesn't really say.
Anyone got any ideas as to what to check/adjust or is it likely a case of a new switch and are these hard to fit?
Thanks for any input
digger
DiggerTunstill is offline   Reply With Quote
Old 06-11-2007   #2 (permalink)
If you take the two wires off the switch (if it's a simple switch) and short them out I would assume your brake light would illuminate.
That would tell you your switch is either too far out of adjustment or knackered.
Good luck with fixing it !!
Safe riding.
Regards,
Graeme.
graeme is offline   Reply With Quote
Brake Light /Oil Seep/Headlight Adjustment T-Rex The Rocket Science Forum 10 02-11-2008 05:46 PM
Rear Brake Pedal Adjustment? meyers_john Twins Technical Talk 8 12-18-2006 07:48 PM
Rear brake pedal adjustment on 2004 Sprint RS ? Blissed Sprint Forum 2 04-28-2006 09:05 PM
rear brake lever adjustment? pdog Modifications & Workshop Talk 0 07-14-2004 10:28 PM
Rear Brake Light Switch GeoffE Modifications & Workshop Talk 2 03-29-2004 11:12 AM
