Jon, Noj,
Thanks for the replies. I did check the tightness of the bolts - a number of people do seem to have had an issue with them. Luckily mine are OK.
I just find that - especially when changing gear - the left peg tends to rotate a bit and 'follow' my foot upwards, and the only obvious fix I can see would be a stronger spring to keep it held in position.
All the Best,
Phil.
