Old 05-30-2007   #1 (permalink)
Favorite Bike: Tiger 1050
Rincewind's Avatar
I found a small oil leak on my right-hand oil cover by the crank.
Here are some pics -
Pic 1
Pic 2
I am wondering if anyone else has experienced this leak. It looks like the later 955i Tigers have the same cover.
Yesterday was the first I had seen this leaking - I cleaned the bike and will see if it reappears.
Do you think this is a symptom of oil overfill? Is a new gasket required if the leak persists? Thanks!
Rincewind is offline   Reply With Quote
Old 05-30-2007   #2 (permalink)
Favorite Bike: Tiger 1050 '08
Other Motorcycle: Tiger 955i '06
It appears to be the seal. Or maybe It can be tightened a bit and the leak disappears?
It does not seem to be sign of overfill. You would have to put 10 litres of oil at least
slayer is offline   Reply With Quote
Old 05-30-2007   #3 (permalink)
Rincewind's Avatar
I was able to get the torque figure and found that it was not tightened to spec, so I tightened it. Hopefully the gasket is still ok. I will watch the area. Thanks for the response.
Cam/Valve Cover oil leak krautfed Triumph SuperSports 7 08-23-2007 01:27 PM
oil leak by cam cover. kidkazi Twins Technical Talk 18 06-27-2007 08:49 AM
oil leak at value cover gasket RT Twins Technical Talk 14 01-14-2007 11:45 PM
Oil leak...left side cover...ideas for a fix? markfly Hinckley Classic Triples 7 06-15-2005 11:12 AM
Clutch cover oil leak TJSpeedmaster Triumph SuperSports 1 07-21-2004 10:14 PM
