OK, this could be the cause of a "warped" disk. No one ever said nuthin' to me, a certified non-racer, about this break-in procedure so I am a little suspicious about the necessity. If riding along a two lane road for miles on end with occassional braking is going to leave deposits of cementite then the technology could use some tweaking.
I did ask if Triumph would replace the pads along with the disks but those are considered consummables and therefore not under warranty.
I also understood that a warped disk would give some feel through the lever and a thickness problem would not. My experience is the latter. Seems like there are multiple explanations for the problem but I still don't know that this is the answer. Good to read, though. Thanks
Sometimes it takes a whole tank before one can think straight
