Took my bike out a couple of days ago. Weather fine and warm. Rode for about 30 mins in city traffic (3500 rpm or over most of the time) to get where I was going. Parked the bike and went to do a little task. 5 minutes later came out and couldn't start the thing!! It gave all the symptoms of a flat battery except that the lights were bright and the horn was fine. It cranked terribly slowly then the solenoidd started chattering. Tried a number of times with no success, even failed at push starting. UNfortunately I had no test equipment so couldn't tell if it was battery or otherwise.
Finally got a jump start and it went immediately. Rode home, shut it down and tried it again after letting it sit for 30 minutes and started first time.
Have ridden it to and from work every day since then and it shows no signs of playing up. It's got me stumped ..... and concerned that I have an intermittent fault that will come back to bite me at the worst time.
Anyone had same / similar problems? :???:
