Motorcycle.com
Old 03-25-2007   #1 (permalink)
clarge13
My fuel gauge does not work now. I get the following error code from Tune Boy.
P0463 Fuel level sensor input above acceptable maximum voltage (shorted high)
If I unplug the sensor I get the same code. Tank is right full. Would the sensor inside the tank be stuck? or could there be a short or break in the line? I get 5 volts at the plug.
Bike has been off the road till now for the winter with low fuel in the tank.
Old 03-26-2007   #2 (permalink)
Favorite Bike: Tiger 1050 '08
Other Motorcycle: Tiger 955i '06
did you also clear error code after you unplugged the sensor ?
Additionally there should be 2 pins in the fuel sensor connector. If you connect voltmeter between them and between each pin and ground what voltage it gives ?
slayer is offline   Reply With Quote
Old 03-26-2007   #3 (permalink)
clarge13
I get 5.04 volts across the terminals when I turn the bike on with it unplugged. I get 1.04 volts with the connector plugged in. 86 ohms across the connector to the the sensor. With that there should not be a broken wire. Yes I did clear the error code. that was the first thing I did as I did have an error code for the fuel pump. That will happen when you have the tank off and turn the thing on.
thanks
Old 03-31-2007   #4 (permalink)
jstormer
gents, i have an 04 tiger whose fuel gauge stays in the red. the low fuel indicator is always on. since this is the first problem i've had with the bike, i don't yet have a manual.
i've looked for the obvious things (connectors, fuses, etc.), but found nothing. please bring me up to speed as to the location of the sensor and where the voltages below can be measured. maybe i'll spot something once pointed in the right direction.
also, is the tune boy essential for troubleshooting? i don't have it. so, i'm guessing that i can't retrieve/clear error codes.
jim
Old 04-01-2007   #5 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
That is about right for empty (IIRC it's around 93). Sounds like you have the same kind of problem I have (it's come back again even though I thought I'd fixed it). So it's back to the trip meter.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 06-14-2007   #6 (permalink)
clarge13
Solved the problem by installing a new fuel float. Easy to install by just taking off the 4 bolts that hold the sensor in the tank. More work to get the tank off.
Paint issues with Bonneville Fuel Tanks SGTSnacks Twins Technical Talk 7 09-12-2007 07:05 PM
Your help with fuel issues jackella Speed Triple Forum 0 05-19-2007 06:25 PM
Fuel Issues with Legend skeeter1949 Hinckley Classic Triples 8 04-30-2007 06:05 PM
Fuel Pump Issues ColoradoCarving Sprint Forum 2 09-09-2006 06:45 PM
More stalling / fuel issues MilwFreddy Trophy 18 12-29-2005 02:37 PM
