On 2007-01-19 09:42, TexasTri wrote:
Has anyone else tried this themselves, guess I'll have to do a search.
There's loads of stuff on one of the Yahoo forums......
MickMaguire wrote:
This REALLY is not something to be messing around with. Get it wrong and you could end up with the equivalent of a high speed blowout, which could lead to serious injury or death!
You mean exactly the same as when I get a screw through an inner tube? That happened to me at around 60 on my Commando and the rider following was astonished I managed to stay on, with the back wheel trying to overtake the front (alternating which side it wanted to be). I reckon the worst that will happen is that I may get a slow leak. Remember all the pressure is pushing the sealant against the joint.
Tubeless punctures are far easier to deal with on the road than are tubes, and given the struggle I had breaking beads it's not something I'd want to try outside the workshop.
Oh, and close reading of the web site of the company you may be referring to (wheel works) shows me they use exactly the same product......
I had extensive conversations with an expert consultant at the supplier, who was quite happy with my proposed use of his product. Oh, and he gave me it free as it was slightly out of date.....
speedjunkie wrote:
If you decide to do it, rough up the area you're sealing with scotch bright or sandpaper. Gives the sealant better adhesion. Next clean the area well with alcohol or MEK/MPK. Seal the spoke ends and smooth just enough so there's not alot of excess with a tongue depresser, ensuring there are no air bubbles. Let the sealer cure. Install tubeless valve stem. Install tire, inflate, check for leaks. Redo if necessary.
That's exactly what I did, but used a small wire brush in a Dremel to clean up, followed by MEK (again supplied by my friendly consultant). There was a fair amount of powdery corrosion around the place.
I used two coats of sealant, the first quite thin to ensure penetration into the spoke end and around the nipple, following up when that had cured (which took a couple of days) with another to ensure any slight gaps were filled. I applied both coats with a small brush to make sure I got it well into gaps.
TBH the hardest part was breaking the bead on the rear tyre.
I will indeed provide an update later in the year.
<edit> Oh, and of course I am not advocating anyone else does this.......</edit>
[ This message was edited by: iansoady on 2007-01-20 06:43 ]
