Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
Old 09-25-2006   #1 (permalink)
Favorite Bike: tiger 955i
Other Motorcycle: 06 speedmaster
Extra Motorcycle: tiger 955i 06
Does anyone know or have the dimensions for the valve shim tool from triumph so I can make 1?????????????
its gggggrrrrrreeeeeeeeaaaaaaaaattttttttttt
malc is offline   Reply With Quote
Old 09-25-2006   #2 (permalink)
Tassie_Tiger's Avatar
Hi Malc,
Just do a search on this site and look for 'valve'. It will return a design for the tool, plus a valve adjustment worksheet.
Haven't done it myself, but when the warranty runs out I'll give it a go.
Good luck, and let us know how it works out!
Roger Harvey
Hobart, Tasmania
Tassie_Tiger is offline   Reply With Quote
Old 09-25-2006   #3 (permalink)
Sorry Malc, searching using only 'valve' just returns the worksheet. Search using 'valve tool'.
Roger Harvey
Hobart, Tasmania
Old 09-25-2006   #4 (permalink)
Just go to 'Downloads' and 'Technical Aids & Information'
Cheers again!
Roger Harvey
Hobart, Tasmania
Old 09-25-2006   #5 (permalink)
Favorite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
When I search, I get squat, nada. It's my lack of understanding the search engine here. I've never been able to get it to return anything useful. Any hints?
tyrebyter is offline   Reply With Quote
Old 09-26-2006   #6 (permalink)
A while back I posted some drawings of the tool. PM me for a copy. Note that I got the dimensions from several other people and don't know for sure if they're spot on. You can construct and make slight mods as required. Any chance you could make two?
[ This message was edited by: guydan on 2006-09-26 05:45 ]
Later,
Doug
guydan is offline   Reply With Quote
Old 09-26-2006   #7 (permalink)
Hey Guydan,
Did that spray paint template of the valve tool help at all?
Old 09-26-2006   #8 (permalink)
Yeah, a little bit. I was able to confirm some of the hole spacings. I haven't built the tool yet to really verify all the dimensions...
Later,
Doug
Old 09-27-2006   #9 (permalink)
I will see if I can get 2 made up also.
Does anyone know if the thickness of the material that Im using is critical.
also does anyone have any pics of the tool & how to use 1 correctly.
Cheers Malc
Old 09-27-2006   #10 (permalink)
Jack Lilley have a picture of the genuine Triumph tool on their website here, and the Haynes Manual has illustrated instructions for how to carry out the task.
As I posted after I did the 24000 service on mine, I'd go about checking the clearances before you go to the trouble of manufacturing the tool. My Tiger is over 27000 miles and the valves are all still in spec from new. Could buy yourself a bit more time in which to manufacture it :wink:
tcowjww is offline   Reply With Quote
Valve Shim Removal Tool Tassie_Tiger Tiger Workshop 9 12-10-2007 08:55 AM
Triumph Valve Shim Tool (T3880012) trotsky Sprint Forum 4 09-14-2007 12:53 AM
Valve Shim Removal Tool Bluetiger901 Modifications & Workshop Talk 1 01-15-2007 12:34 PM
955 shim tool malc Modifications & Workshop Talk 5 10-30-2006 04:55 AM
Valve Shim Removal Tool? Wychall Hinckley Classic Triples 1 10-08-2006 01:49 PM
