Old 09-11-2006   #1 (permalink)
Tenere
Had some bother starting the 955 after a spell parked up in the garage and a flat battery. Charged the battery and it was still a sod to start, but it did eventually after a tussle and seems fine now......except the money lamp (engine management) is lit. I'm fairly sure there's nothing really wrong with the bike and I don't want to have to book an expensive trip to the dealer. Is there a way to reset the system? I'm pretty sure a reset would see the lamp stay out but is it possible without the Triumph tool?
Old 09-11-2006   #2 (permalink)
Favorite Bike: 2004 Bonneville
Other Motorcycle: 2002 Tiger
I think that the engine light will go out after 3 starts or something like that... I wouldn't let it bother you unless it stays on after several rides... This is normal when the battery has been disconnected...
Spacecom ;)
'02 Tiger 955i
'04 Bonnie
Spacecom is offline   Reply With Quote
Old 09-11-2006   #3 (permalink)
Tenere
Wow Spacecom, that's heartening (for me and the bank manager!) hope you're right....thanks.
Old 09-11-2006   #4 (permalink)
Indeed - it worked for me.
The bike needs to be run from cold to the point at which the cooling fan cuts in, three times. This can involve normal riding.
I sorted mine over a period of two days - I started it from cold each time, and when I'd reached my destination I'd leave it idling in the car park until the fan cut in before turning the engine off.
Problem solved!
tcowjww is offline   Reply With Quote
Old 09-11-2006   #5 (permalink)
Tenere
Bizarre! Do I need to walk around it 3 times backwards chanting some spell as well?!......thanks tcowjww feeling much happier now.
Old 09-11-2006   #6 (permalink)
naked.
it's what the gallery section is for
Cheers,
See the Blog of the Deconstructed Don Kyot
kyot is offline   Reply With Quote
Old 09-13-2006   #7 (permalink)
Favorite Bike: Maggie, my 1999 yellow Ti
TucsonBill's Avatar
Other Motorcycle: 1989 Honda NX650 (Dominat
Extra Motorcycle: 1968 Honda CT90
I usually sacrifice a javalina - a wild desert peccary - within sight of the Tiger when the Engine Management light comes on. The light goes off at the next start. No need to be naked.
Might be tough getting a javalina in the UK, especially in Yorkshire!
William Fee
Iron Butt #26777
Tucson, Arizona
TucsonBill is offline   Reply With Quote
Old 09-13-2006   #8 (permalink)
pineygroveshop's Avatar
Virgin sacrifice will suffice.
Cheers,
Stephen
Pack Leader
CARAT
pineygroveshop is offline   Reply With Quote
Old 09-13-2006   #9 (permalink)
Favorite Bike: '03 Sprint RS
steventhechef's Avatar
Can I watch?
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 10-17-2006   #10 (permalink)
Where do you find them?
petjamrut is offline   Reply With Quote
Help – Chain tensioning woes on an ’04 ST RexxyPup Sprint Forum 15 08-14-2006 02:48 AM
America – Service Related Question Britrover Twins Technical Talk 5 07-12-2006 01:25 PM
Hooliganism – what a bike :) corners Speed Triple Forum 22 04-03-2006 06:54 AM
Pictures Attached – Custom America Britrover Twins Talk 31 03-20-2006 08:26 PM
S.O.L. – Save our language!! Speed Triple Forum 40 05-03-2005 12:48 PM
