Bypass the oxygen sensor and smooth things out in traffic.
Maybe this info will help some of you:
On my new Tiger '05 I have been well impressed with everything except, in traffic:
1. the ultra smooth injection got ratty
2. strange resonances could be felt through the footpegs at part throttle,
3. cutting out in traffic and when decelerating up to roundabouts
- spoilt an otherwise perfect bike. I am comparing with my previous '01 Sprint ST and an '03 Tiger I took a long test ride on. The symptoms were unacceptable and I was either going to fit a Power Commander or sell the bike.
I found out that the oxygen sensor in the exhaust header feeds into the ECU unit, which attempts to achieve a particular fuel/air ratio by leaning out the fuel injection at anything over 2500 rpm and any throttle position less then 30% full open. This is done deliberately to pass emissions tests.
Dynojet supply an oxygen sensor bypass plug-in for lots of bikes which fools the ECU into thinking the air/fuel ratio is perfect and stops trying to lean the mixture. There is one for Triumph 9551 engines. Its only £16 and plugs straight into the wiring harness.
Why do some Triumphs exhibit this more than others ? I am told it is because the oxygen sensors vary in output by +/- 15%, so some bikes are not affected while others are. You can just unplug the oxygen sensor but then your engine management warning light will be ON
permanently.
The man at Dynojet tells me they developed the bypass because even when customers had PowerCommanders fitted, this ECU leaning feature would work against the PowerCommander which was trying to achieve the best fuelling.
See
www.dynojet.co.uk/pc/accessories.html (bottom of page).
You don't need to buy a PowerCommander to get the results.
See
www.dynojet.co.uk/pc/index.html for the part numbers for different bikes.
I have done 2000 miles now with the bypass ftted. No negative side effects. I noticed the exhaust outlet colour has changed from a white brown to a normal grey.
After fittng this bypass, 1 and 3 are gone and 2 is reduced to acceptable levels (note this is with stock tune and can). I am now very happy with the bike.
Hope this helps some of you. Maybe it won't work with a race can. At £16 its worth a try
Paul
