After removing the Evap system my bike ran well till Friday. About half way in the Engine Management Light came on and the engine started misfiring. I was able to limp to work.
At the end of the day it started right up and again, about half way home the engine started misfiring. The Engine Management Light has continued to stay on which makes sense.
I'm ruling out the plugs and thinking it must be one of the sensors for the ECM. The symptoms are similar to my TBS when the Ignition Sensor failed. My guess is on the Tiger its counterpart is the Crankshaft Position Sensor.
I found references to some temperature sensor and stepper motor issues that make the ECM deduce the engine is cold so it enriches the air/fuel mix.
It seems all these issues are detectable with the EFI Diagnostics Tool that an Official Triumph Mechanic has, but I don't. I'm considering the Tune-Boy and am wondering if anyone knows if the error codes are *codes* that you need a key to decipher or *messages* that tell you what’s malfunctioning?
Gary
Oahu, Hawaii
