» Links |
| Tiger Workshop Shop Talk, Ideas, Hints, and Tips for smooth running. |
07-11-2006
I'm about to replace the rear and front pads on my '05, per the '01 shop manual - any prior advice would be welcomed.
Thanks,
Walt
OAK
Get a very good flat screwdriver that fits or you will***** up the allen screw cover.
clean everything before you start
a G clamp is useful for pushing the pistons back
copperslip all the bearing surfaces except the rubber boot
don't forget to take some fluid out if you have toped up during the life of the pads.
good luck
07-12-2006
good luck
Thanks -
F.Y.I.
Found a distributor of "Coppaslip", here, in the U.S.
They will be sending a tube of this stuff to me as a sample. However, they said any "anti-seize", high-temp, key: "high-temp", grease is acceptable for this sort of application.
[ This message was edited by: TiggerTwo on 2006-07-12 09:18 ]
OAK
07-12-2006
Formula Extreme Favorite Bike: '06 Scrambler
Posts: 675 Other Motorcycle: '07 F650 GS
On 2006-07-12 08:33, TiggerTwo wrote:
Thanks -
F.Y.I.
They will be sending a tube of this stuff to me as a sample. However, They said any "anti-seize", high-temp, key "high-temp" grease is acceptable for this sort of application.
That is true, any good anti-seize is fine. The rest of Robbie's suggestions are spot on as usual. I find it useful to regularly take off the caliper pins so that they don't seize but I ride the bike in the winter in Maine...
Fred
No such thing as cold weather, just inappropriate clothing.
07-13-2006
Fred
A lot of High temp anti-seize greases are based on Molybdenum disulfide. we have here Moly-slip
Moly turns abrasive if contaminated by water
Moly is OK for inside an engine but not for things such as calipers and chains
07-13-2006
Hi Fred and Robbie,
Thanks for the advice. A tube is on it's way. In the mean time I'd really like to find one without the Molybdenum disulfide base - any suggestions?
Also, the shop manual describes the front pad replacement procedure without removing the calipers (page 13.9). Then it goes on to say that the rear pad procedure is the same as the front and one must refer to the front procedure (page 13.17).
Almost as if they are saying to use the disc to retain the pistons as the pad is withdrawn.
Would be interesting to hear an opinion on this. Perhaps I'm mis-interpreting the procedure.
[ This message was edited by: TiggerTwo on 2006-07-13 06:50 ]
OAK
07-13-2006
Formula Extreme Favorite Bike: 2004 Tiger 955i
Posts: 849 Other Motorcycle: 1955 Velocette Viper Extra Motorcycle: 1956 NSU Quickly
You can do it like that but I prefer to whip the caliper off and have a good look at the pistons, clean them up etc. It's only a couple of bolts to remove.
Ian
2004 Tiger 955i
1955 Velocette Viper.
07-13-2006
So, you pop out the pistons and wipe 'em down?
Sound's like good advice.
Thanks ~
OAK
07-13-2006
Fred
Ribbie-
Thanks, I didn't know that. I quess that is my one thing for today
Fred
07-13-2006
NO !! Warning !! Warning !! missread !! missread !! :???:
i think what iansoady meant was to clean the part of the pistons that you can see, without removing them. when you have the caliper out it gives you a chance to check the piston for marks, scores and freedom of movement and also check the dust seal for splits. try NOT to pop the pistons out unless you are overhauling them.
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
