I ordered EBC HH brake pads from kneedraggers.com at $26 for a set. I ordered two front sets and one rear set. The front came as ordered; however the rear set that I received were not the correct size or composition. When I called the source, I was told that the VIN mattered.
It was very difficult to get resolution of this issue when I called Kneedraggers; however, after multiple attempts, I spoke with a fella that was able to offer to send me the correct pads and a UPS "call tag."
If you decide to use this source, you should first determine if front and rear pads on your bike are the same and order three sets of the same.
In any case, I could have ordered three sets of the same type as the front and rear pads are the same on my Tiger.
I ordered front and rear though I only needed the rear for now. They fit a treat and will test this weekend.
Cheers,
Stephen
Pack Leader
CARAT
