Coincidentally, I just had clutch-side handguard off last night. Don't know whether the '00 is exactly like my '02, but if it is, there should be nothing (but friction where it goes through the clutch lever) which prevents it from coming out.
I would recommend taking a small piece of wood and pressing up on the bottom of the bolt while unscrewing it with the allen key. If that doesn't work, I would put the nut back on (only a couple of turns) and tap it upwards with a plastic-faced hammer, then try unscrewing it out.
It should come out! Good luck.
Tom
