BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Trident-Exhausts.com
Old 06-29-2006   #1 (permalink)
IanE
Can anyone tell me the part numbers for the rear wheel bearings for a 1999 fuel injected Tiger? I need to go and get them tomorrow...
TIA
IanE
Old 06-30-2006   #2 (permalink)
blacktiger's Avatar
Knock the old ones out and take them with you.
H
'02 Tiger955i in black.
Old 06-30-2006   #3 (permalink)
IanE
I tried that last time and found the back end was alarmingly unstable in sweeping corners on the way to the bearing factors. :razz:
Anyway, I rang Jack Lilleys and their parts man obligingly came up with a number. Hope he is right...
Cheers
IanE
Old 06-30-2006   #4 (permalink)
pineygroveshop's Avatar
And the number is? Did they work?
Cheers,
Stephen
Pack Leader
CARAT
pineygroveshop is offline   Reply With Quote
Old 07-01-2006   #5 (permalink)
blacktiger's Avatar
[quote]
Cheers
IanE
Oh! Sorry, I assume everyone has a cage as well.
[ This message was edited by: blacktiger on 2006-07-01 05:15 ]
H
Old 07-02-2006   #6 (permalink)
IanE
He quoted 6204 2RS, and I'm now going tomorrow morning so we'll see.
Oh. and I do have other transport but I'm getting a dealer to do the replacemnent as the bearing factor and the dealer are close together half an hour away from home, and the dealer has to issue the new MoT so I want to go on the bike.
Cheers
IanE
Old 07-03-2006   #7 (permalink)
IanE
He was half right. The definitive answer is one side is 6204 2RS, and one is 6304 2RS. Luckily the dealer had the 6304 in stock so they were able to complete the job.
All fixed and MoT'd and off to its new owner...
Cheers
IanE
Old 07-03-2006   #8 (permalink)
marauder2's Avatar
have you replaced all three bearings in the rear wheel??,not just the two outer ones,that middle one is one everyone misses.
marauder2 is offline   Reply With Quote
rear wheel bearing ricster Sprint Forum 1 01-31-2008 12:15 PM
Bearing part numbers kc5deb Sprint Forum 6 01-20-2008 09:57 PM
wheel bearing part numbers etc bendavanza Twins Technical Talk 6 11-06-2007 05:07 PM
Front wheel bearing numbers ? BorgCymru Twins Technical Talk 0 07-23-2007 02:42 PM
rear wheel bearing Rod The Rocket Science Forum 2 07-12-2007 06:52 PM
