Old 04-20-2006   #1 (permalink)
Thought I'd follow-up my previous posts regarding available power output discussion.
I contacted Triumph U.K. and spoke with the Chris in Tech support.
My question was related to my interpretation of the usable power from the 40a alternator on the my '05 Tiger and '01 Trophy; both having 40A alternators but 30A system fuses.
Chris confirmed that, yes, the 30A fuse is the limiting factor.
So, the maximum, usable current draw from the system and within the Triumph specifications is ~30A or 360 Watts of power.
I also asked Chris about wire wheels for the '05 Tiger. I've created a separate post on this.
OAK
TiggerTwo is offline   Reply With Quote
Old 07-04-2007   #2 (permalink)
armarra's Avatar
Hi,
I wonder if the 40A can be accessed by the use of aftermarket fuse accessories connected directly to the battery.
for example,
fog lights
heated seats
heater grips.
gps power
my thoughts...and correct me if I'm wrong is that the fuses are between the battery and the accessories, so that if more current than expected is drawn from the wiring loom, then the fuses do their job and localise the break.
The 40A alternator is not a waste if you access the difference in aftermarket accessories with their own fuses, straight off the battery.
your thoughts ?
:wink: :wink:
My other Green Triumph has 4 wheels and removable roof and I really enjoy it's note. But it is nice to have a new Trumpy.
armarra is offline   Reply With Quote
Does the charging system fuse limit the available asscessory power? TiggerTwo Modifications & Workshop Talk 5 07-04-2007 11:00 PM
HELP with electrical (fuse) Sam56 Twins Technical Talk 5 04-30-2007 04:16 PM
Auxiliary Fuse/Power Block boreilly Sprint Forum 3 03-28-2007 01:47 AM
Does the Charging system fuse limit the available accessory power? TiggerTwo Tiger Workshop 6 03-26-2006 04:41 PM
Please Help!!!! Cooling fan, Main fuse issue, Electrical issues Modifications & Workshop Talk 10 07-28-2004 09:33 AM
