Hi all,
Hope you can help me with these two questions?
Have had the fuel connectors replaced by a recall, and was going to remove the tank to check the plugs and route some audio/power cables when I noticed -
1) the lower fuel connector (red) is connected to the same side fuel rail and is kinked quite badly & the top connector (silver) is connected to the far side rail. The manual shows the flow the other way round. Is this the right way round or does it not matter?
2) I seem to have hoses connected each side of the tank, running front to back, which are not mentioned in the manual, and because they run between the frame and are wedged in with the loom etc, make it impossible to remove tank with them in place. Do I need to drain the tank and remove these hoses for tank removal, and if so, what clips/fasteners can anyone recommend.
Sorry if this has been covered, but I have searched through messages.
Many thanks in anticipation.
Andy
I\'d rather have a bottle in front of me than a frontal lobotomy
