Motorcycle.com
Old 03-15-2006   #1 (permalink)
Following on from yesterday's general chat item on 'how do I stop that bl**dy alarm arming itself'....
Where's a decent grounding/earthing point near the Datatool unit ?
Read the instructions yesterday and if I earth the yellow wire it doesn't self arm, my preferred option for hopping on and off I think.
FifeTiger is offline   Reply With Quote
Old 03-15-2006   #2 (permalink)
Hi FifeTiger,
Note that grounding the yellow wire doesn't stop the alarm from self-arming, it just stops the nudge sensor from automatically activating with the rest of the system. So after turning the ignition off, the bike will still auto-arm after the delay period (the immobiliser is active, and the alarm will still be triggered if the iginition circuit is energised, or the tamper-switch is... well... tampered with!), it's just that it won't squeak or trigger if you move or nudge the bike, unless you manually press the oval remote-control button to enable the nudge sensor.
If the Datatool alarm is as fitted by Triumph (as mine was) there were a bunch of female bullet connectors under the rear cowling area which were all earthed - presumably because the brown, white and yellow wires were all equipped with male bullet connectors so that any desired option configuration can be achieved with ease, just by plugging the correct male bullet connector into any of the earthed female connectors. I earthed the white one for the benefit of my neighbours :wink:
HTH!
Tim.
tcowjww is offline   Reply With Quote
Old 03-15-2006   #3 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
I earthed mine to one of the ECU mounting bolts which is about 6 inches or so away. Quite neat.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 03-16-2006   #4 (permalink)
ok I'll have a look.
My instruction book definitely says yellow to prevent self arming though.
Trial and error should sort that out though !
Just a question of how many nuts and bolts I need to undo to get to the control unit whether I can be bothered.
Is there any point in UK RAT anymore? Richard RAT - United Kingdom 9 01-30-2008 02:04 PM
Earthing After Market Indicators. amanger Twins Technical Talk 6 10-30-2007 10:34 AM
Point 6 Ton Up Silverado57 Twins Talk 13 01-13-2006 02:18 PM
Earthing to battery terminal JohnRimmer Hinckley Classic Triples 2 07-21-2005 09:32 PM
