Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
ShopTriumph.com
Old 03-04-2006   #1 (permalink)
llewpants
One quick question. I have just bought a mudguard extension for the front of my 2000 885i Tiger. It came with 4 plastic rivets to attach to existing mudguard. Do I use these rivets as I would use normal metal ones? Are they strong enough?
Anyone used them before? Quick response required as I was going to fit them later today, as salt spray is eating my bike.
Cheers
Llewpants :???:
Old 03-04-2006   #2 (permalink)
Yes they are strong enough.
TF.
Tigerfeet is offline   Reply With Quote
Old 03-07-2006   #3 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
TF.
I felt they were a bit feeble and backed them up with silicon. They also seemed very near the tyre so I chopped off the folded over bit on the inside.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 03-07-2006   #4 (permalink)
Hi Folks
I removed those plastic rivets and replaced them with those plastic thingys and nuts that are used on ones number plate ..
Regards
Alan
kraftdinners is offline   Reply With Quote
Old 03-08-2006   #5 (permalink)
I fitted the mudguard extension three years ago using the supplied plastic rivets and no other fixing. It's still on there, and still not loose.
Foxee is offline   Reply With Quote
Old 03-09-2006   #6 (permalink)
blacktiger's Avatar
Ditto.
I would recommend drilling the hole 0.5mm smaller than recommended. Makes for a tighter fit.
H
'02 Tiger955i in black.
Old 03-10-2006   #7 (permalink)
Mine hasn't budged in over 20k miles and has only had 3 of the supplied plastic rivets (one got mashed) since day one.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
front mudguard extension installation dart330 Sprint Forum 5 04-28-2007 11:26 PM
Front mudguard extenders bobbo T3 Sport / Touring Forum 3 01-26-2007 03:48 PM
'03 Front Fender Extension JasonS Sprint Forum 3 04-11-2006 12:45 PM
Can't remove front mudguard aniseed T3 Sport / Touring Forum 5 02-24-2006 05:36 PM
Triumph front mudguard extension Hinckley Classic Triples 11 05-19-2004 03:11 AM
