Hello all
New member with a 2000my Tiger 900i. I have just noticed an oil leak (well weeping really) from a pipe.
See photo
http://www.triumphrat.net/modules.ph...view_photo.php
It is the pipe that does a 90 degree bend (just above the gear level) up wards to wards the tank (by the silver bracket).
I have looked on the Haynes manual at it is not motioned?
I think it is a breather pipe. The oil is collecting by the bracket about half way up. As I am no expert on Tigers I do not want to start pulling bits off until I have some advice.
Has anyone had this problem, is there a fix, or do I have to order a new pipe if so what is it called (part No etc)
Thanks in advance.
Llewpants :???: :???: :???:
