Old 02-05-2006   #1 (permalink)
TomJ
After trying to find the source of a low speed clicking noise on my bike I have found that when the chain is in a certain position the chain becomes so tight that you can hardly move it (when adjusted on site stand for 40mm movement in a slack spot). I guess that this means its time for a new chain and sprockets?
Old 02-08-2006   #2 (permalink)
Favorite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
How many miles?
tyrebyter is offline   Reply With Quote
Old 02-08-2006   #3 (permalink)
Favorite Bike: 01 Tiger
Other Motorcycle: 02 Sprint RS
Extra Motorcycle: another 01 Tiger
You need to adjust the chain to the tight spot. I did have a master link go bad on one of my chains. It was pretty easy to see the long link as you roll it onto the rear sprocket. All the other links roll right into the tooth then the long link come high on the tooth. Mine destroyed my counter shaft sprocket before I fixed it. I swapped an old sprocket it on to it after repairing the master link. I replaced the chain and sprockets after getting through the winter.
nortoncharlie is offline   Reply With Quote
Old 02-08-2006   #4 (permalink)
BigStripey's Avatar
Any tight spot like that on a chain is a bad spot!, it is the beginning of the end for the chain and sprockets.
Time for new is the safest bet by far. If you can stretch to it, go with a DID 'x' ring or similar. I can only talk from experience and i have found them to be excellent chains. It is 530 VM chain that you need.
[ This message was edited by: BigStripey on 2006-02-08 23:51 ]
Big Stripey
BigStripey is offline   Reply With Quote
Old 02-08-2006   #5 (permalink)
I'll ditto Jim,if you've got a tight spot on the chain it's time to bail out and buy new chain and sprockets.
winger is offline   Reply With Quote
Old 02-15-2006   #6 (permalink)
Favorite Bike: Scrambler
johnyC's Avatar
Although my chain and rear sprocket are still in reasonable nick, I found the 18 tooth front was 'hooked' when I fitted a new 19 tooth recently.
It's probably too late to save this chain and rear sprocket, but when I replace them next I'm going to start changing out the front sprocket every 5,000 miles and see if that makes any difference to the life of the chain and rear sprocket. I read an article in Motorcycle Sport and Leisure where a bloke did this and thought I'd give it a try.
On a variety of bikes over the years, my personal record for 'O' ring chain life was 12,000 miles on a Ducati M900. I got 10,000 out of the original Triumph chain on my old TBS, both were fitted with Scottoilers and correctly adjusted.
I'm hoping that the sacrificial front sprocket experiment works, anyone else tried it?
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 02-16-2006   #7 (permalink)
With more than just a little abuse, I got 20k miles out of the original chain and sprocket. Changed them for a couple of Renthal sprockets and DID Xring chain.
And the Scottoiler keeps it all nice and clean and lubricated
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
excessive wear on chain guide Kitson Hinckley Classic Triples 17 06-25-2007 10:56 AM
sprocket changing and chain guard wear or not rckrzy1 Speed Triple Forum 0 07-24-2006 01:54 PM
Bonneville Cam Chain wear webonnielad Modifications & Workshop Talk 2 07-24-2006 04:05 AM
Chain wear / master link Pauley Twins Talk 4 09-07-2005 03:17 PM
Chain Guard Wear Problems Triumph SuperSports 48 10-23-2004 06:54 AM
