BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 01-18-2006   #1 (permalink)
Favorite Bike: 2007 Bonneville Black
Has anyone replaced the shifter shaft seal? Is it a straight forward process that does not involve tranny disassembly?
smartin108 is offline   Reply With Quote
Old 01-21-2006   #2 (permalink)
Favorite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
It's a cake walk. Remove the lever, snap ring and washer. Pry out the old seal with a flat blade screwdriver taking care not to nick the shaft and pop in the new seal with a deep socket of appropriate size. You won't even lose any oil if on a center stand. Ten minutes tops.
tyrebyter is offline   Reply With Quote
Old 01-21-2006   #3 (permalink)
That's good news. Thanks for the response.
clutch shaft seal kiwi tony Tiger Workshop 2 11-26-2007 02:01 PM
Broken shifter shaft ClassiclyMobile Hinckley Classic Triples 35 06-21-2007 08:17 PM
Gear shifter shaft removal dat Twins Technical Talk 3 06-11-2007 09:41 PM
!@# Counter-shaft Sprocket seal ssjones Twins Talk 15 01-25-2006 04:33 PM
Leaking oil seal on output shaft... TThruxton Club Cafe 4 10-25-2005 04:08 PM
