» Links |
| Tiger Workshop Shop Talk, Ideas, Hints, and Tips for smooth running. |
01-08-2006
Guys:
I've been reading posts, reviews, manufacturers websites, etc, and my head hurts! Here's the deal...
I have about 5500 miles on my Anakees with the rear having approximately 2mm of thread left and very flat. I ride exclusively on-road; commuting and Sunday rides, not too aggressive. I want to change to a road-based tire and have three on the list:
Michelin Pilot Road
Conti Road Attack
Avon Azaro AV45/AV46 (if I can find the front)
I'm looking for comments from people with experience; please comment on likely and/or relative life, likes/dislikes, good internet sources, etc.
Thanks in advance.
[ This message was edited by: guydan on 2006-01-08 16:16 ]
Later,
Doug
I was initially going to use BT20's when my Tourances needed changing but given all Bridgestones seem to cup badly decided I wanted something different. I then decided to fit Road Attacks and had them on order but they were out of stock and I needed tyres so after a couple of weeks fitted Pilot Roads. The day I had them fitted I actually saw the Conti's in the flesh in a different size and am glad that I decided against. Yes they get good write ups but in the wet they would give very little cornering grip as there is next to no tread on the sides of the tyres.
The michelins on the other hand have proven to be a revelation.
They heat up very nicely without ever becoming too hot (so hopefully should last a decent length of time - only time will tell though).
stability, road feel and braking are all hugely better. grip wet and dry is also better than the Tourances. The day I had them fitted, it rained all the way home and even without being scrubbed in they offered great feel and grip. After scrubbing them in properly I find them to be fantastic.
Tyres are very subjective though and what one loves another will hate.
So far though i am VERY HAPPY and impressed with the Michelins!
[ This message was edited by: djr on 2006-01-09 01:00 ]
01-09-2006
I have to agree with David, I put on the Pilot Roads a few weeks and a few hundred miles ago. They are the single best improvement I have made to the bike.
The stock Tourances felt wooden. I got great life (11,000 miles) out of them but felt disconnected from the road. I was afraid to lean the bike.
The Pilot Roads give much better feedback and allow me to lean the bike at angles I would never try before.
I have yet to try them in the wet so I can't comment there. Unfortunately I also can't comment on the expected tire life as they are so new.
Another thing, I looked at the BT020's Pilot Roads, Continental Attacks and the Avon Azaro ST's. The only front tires (in our 110/80 19 size) that I could actually find ready for shipment in the US were the Bridgstones and the Michelins. This was about a month ago. I still dont think you can get the front Conti and Avon in the US, but maybe someone can prove me wrong.
If you are interested, Tire Express has the Michelins in stock in our sizes. They are the only place I could find the front.
Good luck,
John
01-10-2006
Supersport 400 Favorite Bike: Tiger 1050
I have switched to BT020's after 6000+ miles on Tourances followed by 8,000+ miles on Pirelli Scorpions.
I would recommended the BT 020's. At first they seem to make the Tiger ride on tippy toe and flop into corners. But after a few miles this translates into much sharper steering. The tyres almost encourage you to ride harder. The ride is much smoother andgrip is better on the road. Braking is also improved. The front profile seems to be more rounded which allows me to get much closer to the edge of the tyre. Grip in the wet is not as good but still ok. Overall I am very pleased. I do take my Tiger off road more than most but this still means I spend 98% on my time on Tarmac. On balance I will probably stick with Road biased tyres for normal use.
I had wanted to try the Avon Azaro but last october Avon told me that the front tyre was out of production while a new die was being manufactured.
Good luck,
adrianmol
01-10-2006
I'll be going for road tyres next. I had 020s on my Sprint RS and they were good. I even did a couple of track days with no problems with grip. The stock Tourances are OK but now they're a bit squared at 6K miles the handlings awful, especially in the wet.
02-27-2006
post deleted
[ This message was edited by: guydan on 2006-02-27 20:11 ]
Later,
Doug
02-28-2006
Not so, I'm onto my third set of 020's and I've yet to see this 'cupping' as you keep harping on about???
The 020's I've got on the tiger are giving me surprisingly more mileage than I expected. I've done just over 3k miles so far and there is loads of tread on them, with no sign of cupping or squaring off. Bridestone 020's get my vote.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
02-28-2006
the cupping normally happens to the front and you wont notice it yet. Once you have changed out the rear and the front starts to get near the limit of its lifespan it will make itself known to you.
Check any bike board about any bike using Bridgestones and you will get feedback about cupping. It is a known Bstone phenomenon. It is more prevalent IMHO where you use the front brake pretty heavily. On my TT600 there was tons of tread left but it felt like riding along ridges constantly and when you looked closely you could actually see the way the tyre had worn unevenly. This is down to the way Bstones are.
Dont get me wrong, I had BT10s on my TT600 and they were great roadtyres. BT20s are as well, I just wanted a different brand so as not to repeat the process and although the Pilot Roads are my first with Michelin on a bike, I am pretty damned sure they will not be my last from this company.
02-28-2006
On 2006-01-08 16:16, guydan wrote:
Guys:
Michelin Pilot Road
Conti Road Attack
Thanks in advance.
Still reading... The Avon AV45 in a 110/80-19 is just hitting the streets here in the US. One other choice that appears to be available is the Metzler Roadtec Z6 (saw the front in the Dennis Kirk catalog). Any opinions on it?
Later,
Doug
02-28-2006
I have just got a 2002 Tiger after a lifetime riding sports bikes; it’s the first bike other than a super sports bike I’ve owned. I am totally blown away by the bikes handling and grip. It’s got a pair of Tourances fitted and I just can’t believe how good they are.
I have always used Bridgestone’s and trust them. I am not sure what you mean buy cupping?? On the rear the tread wears evenly however on the front the rear of the tread block tends to wear first. That said they tend to still last very well indeed.
I suspect that the improvement with road tyres are more down to the shape of the front tyre than compound or tread pattern.
Can you fit road tyres to the spoked wheels with a tube?? Even though they are a tubeless tyre.
