I have an NWS hugger and, whilst it does a smashing job in other areas, it's not designed in a way which would protect the rear caliper particularly.
I had to replace the dust seals on my rear caliper because they were a bit shredded, so I decided to replace the fluid seals simultaneously (all the seals can be purchased separately from the pistons) and it's not too much of a job to replace.
When removing the old seals, remove any oxidisation from the caliper body to ensure the new seals seat properly - make sure you use a material softer than aluminium for your scraper though, otherwise you could damage the caliper.
Something I would be grateful to hear feedback on though is the bleeding of the rear brake caliper. I found that when the caliper is mounted on the bike, the bleed nipple is not at the highest point so it seems to make it impossible to remove all the air from the system when bleeding normally. In the end I removed the caliper from its mountings and bled the system whilst a mate held the caliper with the nipple uppermost and a block of wood between the pistons and the back of the caliper. Is there an easier way to do this (short of parking the bike on a steep hill :wink: )
