Motorcycle.com
Old 12-12-2005   #1 (permalink)
I recently took the tank off my 2004 tiger, carefully noting where everything went (leads/pipes etc) or so I thought. Come to put the tank back on and I noticed that on the left hand side of the tank just above and to the right of the petrol in/out pipes there is what appears to be a vacuum switch/outlet. I can only describe this thing as being about4/5 cms in diameter made of brass with a pipe connectio. Any ideas. Bike runs o.k, just need to know what it does.
Thanks
Bob
Tigerbob is offline   Reply With Quote
Old 12-12-2005   #2 (permalink)
That's your fuel pressure regulator. Not to worry, you didn't forget anything. On some older models there was a tube that attatched to the connector you describe but that has been done away with on newer models. My '03 is the same way.
John
03tiger is offline   Reply With Quote
Old 12-13-2005   #3 (permalink)
Thanks for the reply. It's been driving me around the bend trying to find a pipe or something that would have fitted on the outlet. I can now sleep in peace.
Thanks
Bob :hammer:
Old 12-13-2005   #4 (permalink)
No problem. You will find many "spare items" on these bikes that will give you similar grief. The first time I pulled the airbox there was a spare electrical connector tucked under one of the coil wires. I later learned that Triumph use the same wiring looms on various models and certain connectors only apply to certain bikes.
John
Old 08-11-2006   #5 (permalink)
Favorite Bike: Tiger
madmic's Avatar
Dam, thats good to know, cause I am about to remove my tank to put in a K&N air filter. I might have freaked out if I saw extra wires and fittings. Hey, by the by, anyone know if I have to have the engine remaped if I put in K&N filter? :???:
Dare mighty deeds, win glorious victories even if checkered by defeat.
madmic is offline   Reply With Quote
Bags-Connection smartin108 Twins Talk 1 08-08-2007 06:07 PM
Speed Triple Tank Fuel Connection. ExPat Speed Triple Forum 5 05-27-2007 06:29 PM
better Triumph Tank Bag front connection on RS? Isa Sprint Forum 5 11-03-2005 05:00 PM
Hose connection? Jerry Sprint Forum 2 10-11-2004 07:54 PM
whats that connection for? hyzer Hinckley Classic Triples 2 02-11-2004 01:37 PM
