Old 12-06-2005   #1 (permalink)
Hi Folks, a question , my `05 955i Tiger appears to have a oil seepage from the right side of the engine , it appears to be coming from that plated screw slug ( for want of a better term ) behind the headers, just above the sump...anyone had similar ?..ok its under warranty but was wondering if its any problem unscrewing it and applying some sealant...plus would any oil pee out upon its removal ( looks a possibility )...if so its a dealer job..
many thanks for any tips..
Alan :-D
Alan
kraftdinners is offline   Reply With Quote
Old 12-07-2005   #2 (permalink)
djr
if its under warranty let the dealer sort it out. That way if there is a problem then they can sort it out.
David
My Photo Album
My Tiger pages
djr is offline   Reply With Quote
Old 12-07-2005   #3 (permalink)
Hi Djr.yes you are quite right of course, just thought if I could sorta undo it and reseal it......but thanks for the reply..and the kick up the butt....if you see what I mean :-D
Alan
Alan
Old 12-08-2005   #4 (permalink)
djr
you may well be able to remove the plug but what if the threads have been damaged causing the problem, then you are stuffed. We all do little bits ourselves rather than run to the dealer but personally anything that is engine related I would rather they sort out, just in case
David
My Photo Album
My Tiger pages
Old 12-19-2005   #5 (permalink)
Hi Djr.. glad to report that the source of the leak is sorted, it indeed was that plug, it was not fully tightened according to the dealer, yes I was contemplating doin it myself but why bother, 2 year warranty an all that, and would as you say been well stuffed if the thread gave up in the ally....thanks again all for your advice...appreciated
Regards
Alan
oil seepage Catenaccio Modifications & Workshop Talk 0 08-01-2007 01:40 PM
Oil Seepage HalFpipe Twins Technical Talk 11 06-28-2007 06:30 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
Oil seepage Hornblower The Rocket Science Forum 14 10-04-2006 02:47 PM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
