I took the tank off earlier to route wires for the GPS. According to the manual I should have a vacuum hose running from the RH side to the fuel pressure regulator. I haven't.
I should also have a fuel tank drain hose - haven't got one of those either.
The connection to the roll-over valve appears to be optional which is just as well as I don't have of those either!
I'm not so bothered about the last two but should this vacuum hose be there? This is a 2004 model.
The vacuum pipe thingy hose was discontinued by 2003. Mine hasnt got one from new. Triumph do that sort of thing to keep the nesgroups alive and kicking. :razz:
nehpetsthegrey.
as grey as gandalf but not quite as old
