0Volts at the rectifier !!
Assumed my battery charging issue was a fried rectifier. Turns out it's not so there's £90 wasted for a start.
Mechanic says there's no voltage at the rectifier for it to rectify. He's hoping for a loose or broken wire, worse case is alternator is stuffed.
2002 955 model with 43k on it, should it really have died ? What else could it be ?
