Soupy's PerformanceBikeBanditOPP RacingBritish Motorcycle GearMotorcycle.comMotorcycle.com Classifieds!Trident-Exhausts.com
Bike Bandit
Old 08-15-2009, 08:59 AM   #1 (permalink)
Fuel Gauge Stuck "And Repaired"
This may be of help
I filled up my Tiger 955i 04 plate the gauge only showed 3/4 full but the tank was brimmed.
I took the tank off and removed the bottom plate and took out the fuel mechanism.
It consists of a long tube with a cap on the end, I removed the cap.
The inside of the tube has a long thin curcuit board with a float that shoud move freely up and down as the fuel level changes.
The float on my bike had got wedged 3/4 of the way up the curcuit board.
All it needed was a slight tap to the float and it became free, this fixed the fuel gauge problem. It also happened on a friends tiger, I think pulling the odd wheelie can cause this to happen!
Kazntone is offline   Reply With Quote
Old 08-15-2009, 10:37 AM   #2 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velo Viper/Venom
If the sensor was the early type (ie the float is a white spongy material) this happens a lot. The later one with a dark grey smooth float cures all.....
Ian
2004 Tiger 955i
1955 Velocette Viper / Venom.
iansoady is offline   Reply With Quote
Old 08-23-2009, 03:00 AM   #3 (permalink)
Favourite Bike: 2005 Triumph Tiger
EvilBetty's Avatar
And getting the old ones "un-stuck" is temporary. it will get stuck again later. You can replace the float in some cases, or replace the sending unit with a new one or eBay one from a 2006.
There's no place like 127.0.0.1...
2005 Triumph Tiger - Lucifer Orange
EvilBetty is offline   Reply With Quote
Old 08-23-2009, 09:49 AM   #4 (permalink)
My 2006 is starting to show full and then dropping to empty w/ the fuel light coming on and then back to full or the correct reading. What's with that?
westnash is offline   Reply With Quote
Old 08-23-2009, 05:07 PM   #5 (permalink)
EvilBetty's Avatar
It seems like I've seen someone complain of that before. The float slides up and down a circuit board. It's possible the contacts are corroded or fouled up somehow but that's just a guess.
Old 08-26-2009, 01:37 PM   #6 (permalink)
iansoady's Avatar
There aren't any contacts - the float has a magnet in it which actuates a series of reed switches varying the output resistance.
Ian
2004 Tiger 955i
Old 08-26-2009, 01:40 PM   #7 (permalink)
EvilBetty's Avatar
Yeah I remembered that later.
I actually think that float is bobbing with fuel movement in the tank, then getting stuck now and then. But I thought the 2006's had the updated float in them.
Old 08-26-2009, 07:01 PM   #8 (permalink)
Favourite Bike: Tiger
tyger's Avatar
Other Motorcycle: no other necessary
Have you checked your electrics? Often electrics problems show up first as weird unexplainables. My recent issues with the output from reg/rectifier were relatively sudden and heated. The meltdown at Madame Toussauds... and so I have 10 gauge wire from R/R to battery now, but I digress. Check fuses and wiring for issues.
'05 Triumph Tyger! Tyger! British Racing Green
tyger is offline   Reply With Quote
"Foot Pegs," or "Rear Sets" Dan in Cibolo Twins Talk 4 06-29-2009 01:20 AM
No Taillight in "ON", Have tail in "PARK" zebulonsmith Tiger Workshop 2 07-19-2008 05:15 PM
Combining my "seat heat" and "tune" threads here TheNomad Sprint Forum 10 06-02-2008 01:09 PM
Fuel Sending Unit "Recall" cjmadura Tiger Workshop 1 04-23-2008 01:46 PM
